The openSUSE 13.2 kernel was updated to version 3.16.7.
These security issues were fixed:
- CVE-2014-9322: A local privilege escalation in the x86_64 32bit compatibility signal handling was fixed, which could be used by local attackers to crash the machine or execute code. (bnc#910251)
- CVE-2014-9090: The do_double_fault function in arch/x86/kernel/traps.c in the Linux kernel did not properly handle faults associated with the Stack Segment (SS) segment register, which allowed local users to cause a denial of service (panic) via a modify_ldt system call, as demonstrated by sigreturn_32 in the linux-clock-tests test suite. (bnc#907818)
- CVE-2014-8133: Insufficient validation of TLS register usage could leak information from the kernel stack to userspace. (bnc#909077)
- CVE-2014-3673: The SCTP implementation in the Linux kernel through 3.17.2 allowed remote attackers to cause a denial of service (system crash) via a malformed ASCONF chunk, related to net/sctp/sm_make_chunk.c and net/sctp/sm_statefuns.c (bnc#902346, bnc#902349).
- CVE-2014-3687: The sctp_assoc_lookup_asconf_ack function in net/sctp/associola.c in the SCTP implementation in the Linux kernel through 3.17.2 allowed remote attackers to cause a denial of service (panic) via duplicate ASCONF chunks that triggered an incorrect uncork within the side-effect interpreter (bnc#902349).
- CVE-2014-3688: The SCTP implementation in the Linux kernel before 3.17.4 allowed remote attackers to cause a denial of service (memory consumption) by triggering a large number of chunks in an association's output queue, as demonstrated by ASCONF probes, related to net/sctp/inqueue.c and net/sctp/sm_statefuns.c (bnc#902351).
- CVE-2014-7826: kernel/trace/trace_syscalls.c in the Linux kernel through 3.17.2 did not properly handle private syscall numbers during use of the ftrace subsystem, which allowed local users to gain privileges or cause a denial of service (invalid pointer dereference) via a crafted application (bnc#904013).
- CVE-2014-7841: The sctp_process_param function in net/sctp/sm_make_chunk.c in the SCTP implementation in the Linux kernel before 3.17.4, when ASCONF is used, allowed remote attackers to cause a denial of service (NULL pointer dereference and system crash) via a malformed INIT chunk (bnc#905100).
These non-security issues were fixed:
- ahci: Check and set 64-bit DMA mask for platform AHCI driver (bnc#902632).
- ahci/xgene: Remove logic to set 64-bit DMA mask (bnc#902632).
- ahci_xgene: Skip the PHY and clock initialization if already configured by the firmware (bnc#902632).
- ALSA: hda - Add mute LED control for Lenovo Ideapad Z560 (bnc#665315).
- ALSA: hda/realtek - Add alc_update_coef*_idx() helper (bnc#905068).
- ALSA: hda/realtek - Change EAPD to verb control (bnc#905068).
- ALSA: hda/realtek - Optimize alc888_coef_init() (bnc#905068).
- ALSA: hda/realtek - Restore default value for ALC668 (bnc#905068).
- ALSA: hda/realtek - Update Initial AMP for EAPD control (bnc#905068).
- ALSA: hda/realtek - Update restore default value for ALC282 (bnc#905068).
- ALSA: hda/realtek - Update restore default value for ALC283 (bnc#905068).
- ALSA: hda/realtek - Use alc_write_coef_idx() in alc269_quanta_automake() (bnc#905068).
- ALSA: hda/realtek - Use tables for batch COEF writes/updtes (bnc#905068).
- ALSA: usb-audio: Do not resubmit pending URBs at MIDI error recovery.
- arm64: Add architectural support for PCI (bnc#902632).
- arm64: adjust el0_sync so that a function can be called (bnc#902632).
- arm64: Do not call enable PCI resources when specify PCI_PROBE_ONLY (bnc#902632).
- arm64: dts: Add X-Gene reboot driver dts node (bnc#902632).
- arm64/efi: efistub: cover entire static mem footprint in PE/COFF .text (bnc#902632).
- arm64/efi: efistub: do not abort if base of DRAM is occupied (bnc#902632).
- arm64: fix bug for reloading FPSIMD state after cpu power off (bnc#902632).
- arm64: fix VTTBR_BADDR_MASK (bnc#902632).
- arm64: fpsimd: fix a typo in fpsimd_save_partial_state ENDPROC (bnc#902632).
- arm64/mustang: Disable sgenet and xgenet (bnc#902632).
- arm64: Select reboot driver for X-Gene platform (bnc#902632).
- arm: Add APM Mustang network driver (bnc#902632).
- arm/arm64: KVM: Fix and refactor unmap_range (bnc#902632).
- arm: Define PCI_IOBASE as the base of virtual PCI IO space (bnc#902632).
- asm-generic/io.h: Fix ioport_map() for !CONFIG_GENERIC_IOMAP (bnc#902632).
- ax88179_178a: fix bonding failure (bsc#908253).
- btrfs: Fix and enhance merge_extent_mapping() to insert best fitted extent map.
- btrfs: fix crash of btrfs_release_extent_buffer_page.
- btrfs: fix invalid leaf slot access in btrfs_lookup_extent().
- btrfs: fix kfree on list_head in btrfs_lookup_csums_range error cleanup.
- btrfs: fix lockups from btrfs_clear_path_blocking.
- btrfs: fix race that makes btrfs_lookup_extent_info miss skinny extent items.
- btrfs: Fix the wrong condition judgment about subset extent map.
- btrfs: fix wrong accounting of raid1 data profile in statfs.
- btrfs: send, do not delay dir move if there is a new parent inode.
- config: armv7hl: Disable CONFIG_USB_MUSB_TUSB6010 (bnc#906914).
- cpufreq: arm_big_little: fix module license spec (bnc#902632).
- Delete patches.rpmify/chipidea-clean-up-dependencies (bnc#903986).
- Disable Exynos cpufreq modules.
- drivers/net/fddi/skfp/h/skfbi.h: Remove useless PCI_BASE_2ND macros (bnc#902632).
- drm/i915: Keep vblank interrupts enabled while enabling/disabling planes (bnc#904097).
- drm: Implement O_NONBLOCK support on /dev/dri/cardN (bnc#904097).
- drm/nv50/disp: fix dpms regression on certain boards (bnc#902728).
- drm/radeon: add locking around atombios scratch space usage (bnc#904932).
- drm/radeon: add missing crtc unlock when setting up the MC (bnc#904932).
- drm/radeon/dpm: disable ulv support on SI (bnc#904932).
- drm/radeon: fix endian swapping in vbios fetch for tdp table (bnc#904932).
- drm/radeon: fix speaker allocation setup (bnc#904932).
- drm/radeon: initialize sadb to NULL in the audio code (bnc#904932).
- drm/radeon: make sure mode init is complete in bandwidth_update (bnc#904932).
- drm/radeon: report disconnected for LVDS/eDP with PX if ddc fails (bnc#904417).
- drm/radeon: set correct CE ram size for CIK (bnc#904932).
- drm/radeon: Use drm_malloc_ab instead of kmalloc_array (bnc#904932).
- drm/radeon: use gart for DMA IB tests (bnc#904932).
- drm/radeon: use gart memory for DMA ring tests (bnc#904932).
- drm/tilcdc: Fix the error path in tilcdc_load() (bko#86071).
- hp_accel: Add support for HP ZBook 15 (bnc#905329).
- ideapad-laptop: Change Lenovo Yoga 2 series rfkill handling (bnc#904289).
- Input: i8042 - also set the firmware id for MUXed ports (bnc#897112).
- Input: psmouse - add psmouse_matches_pnp_id helper function (bnc#897112).
- Input: psmouse - add support for detecting FocalTech PS/2 touchpads (bnc#897112).
- Input: synaptics - add min/max quirk for Lenovo T440s (bnc#903748).
- irqchip: gic: preserve gic V2 bypass bits in cpu ctrl register (bnc#902632).
- iwlwifi: dvm: drop non VO frames when flushing (bnc#900786).
- KEYS: Allow special keys (eg. DNS results) to be invalidated by CAP_SYS_ADMIN (bnc#904717).
- KEYS: Fix stale key registration at error path (bnc#908163).
- KEYS: Fix the size of the key description passed to/from userspace (bnc#904717).
- KEYS: Increase root_maxkeys and root_maxbytes sizes (bnc#904717).
- KEYS: request_key() should reget expired keys rather than give EKEYEXPIRED (bnc#904717).
- KEYS: Simplify KEYRING_SEARCH_{NO,DO}_STATE_CHECK flags (bnc#904717).
- KVM: ARM: Add arm,gic-400 compatible support (bnc#902632).
- KVM: ARM: Hack to enable VGIC mapping on 64k PAGE_SIZE kernels (bnc#902633).
- Limit xgbe a0 driver to arm64
- net/xgbe: Add A0 silicon support (bnc#902632).
- of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (bnc#902632).
- of/pci: Add pci_register_io_range() and pci_pio_to_address() (bnc#902632).
- of/pci: Add support for parsing PCI host bridge resources from DT (bnc#902632).
- of/pci: Fix the conversion of IO ranges into IO resources (bnc#902632).
- of/pci: Move of_pci_range_to_resource() to of/address.c (bnc#902632).
- parport: parport_pc, do not remove parent devices early (bnc#856659).
- PCI: Add generic domain handling (bnc#902632).
- PCI: Add pci_remap_iospace() to map bus I/O resources (bnc#902632).
- PCI: xgene: Add APM X-Gene PCIe driver (bnc#902632).
- power: reset: Add generic SYSCON register mapped reset (bnc#902632).
- power: reset: Remove X-Gene reboot driver (bnc#902632).
- quirk for Lenovo Yoga 3: no rfkill switch (bnc#904289).
- reiserfs: destroy allocated commit workqueue.
- rtc: ia64: allow other architectures to use EFI RTC (bnc#902632).
- scripts/tags.sh: Do not specify kind-spec for emacs ctags/etags.
- scripts/tags.sh: fix DEFINE_HASHTABLE in emacs case.
- tags.sh: Fixup regex definition for etags.
- ttusb-dec: buffer overflow in ioctl (bnc#905739).
- usb: Add support for Synopsis H20AHB EHCI host controller (bnc#902632).
- usb: fix hcd h20ahb driver depends (bnc#902632).
- usb: uvc: add a quirk for Dell XPS M1330 webcam (bnc#904539).
- usb: uvc: Fix destruction order in uvc_delete() (bnc#897736).
• https://bugzilla.opensuse.org/show_bug.cgi?id=905100
• https://bugzilla.opensuse.org/show_bug.cgi?id=906914
• https://bugzilla.opensuse.org/show_bug.cgi?id=904417
• https://bugzilla.opensuse.org/show_bug.cgi?id=905068
• https://bugzilla.opensuse.org/show_bug.cgi?id=904097
• https://bugzilla.opensuse.org/show_bug.cgi?id=902346
• https://bugzilla.opensuse.org/show_bug.cgi?id=903986
• https://bugzilla.opensuse.org/show_bug.cgi?id=902351
• https://bugzilla.opensuse.org/show_bug.cgi?id=897112
• https://bugzilla.opensuse.org/show_bug.cgi?id=903748
• https://bugzilla.opensuse.org/show_bug.cgi?id=904289
• https://bugzilla.opensuse.org/show_bug.cgi?id=897736
• https://bugzilla.opensuse.org/show_bug.cgi?id=908253
• https://bugzilla.opensuse.org/show_bug.cgi?id=902728
• https://bugzilla.opensuse.org/show_bug.cgi?id=904539
• https://bugzilla.opensuse.org/show_bug.cgi?id=908163
• https://bugzilla.opensuse.org/show_bug.cgi?id=905739
• https://bugzilla.opensuse.org/show_bug.cgi?id=904717
• https://bugzilla.opensuse.org/show_bug.cgi?id=902349
• https://bugzilla.opensuse.org/show_bug.cgi?id=665315
• https://bugzilla.opensuse.org/show_bug.cgi?id=904932
• https://bugzilla.opensuse.org/show_bug.cgi?id=904013
• https://bugzilla.opensuse.org/show_bug.cgi?id=905329
• https://bugzilla.opensuse.org/show_bug.cgi?id=900786
• https://bugzilla.opensuse.org/show_bug.cgi?id=902632
• https://bugzilla.opensuse.org/show_bug.cgi?id=902633
• https://bugzilla.opensuse.org/show_bug.cgi?id=910251
• https://bugzilla.opensuse.org/show_bug.cgi?id=907818
• https://bugzilla.opensuse.org/show_bug.cgi?id=909077
• https://bugzilla.opensuse.org/show_bug.cgi?id=856659
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3687
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-7841
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-7826
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3673
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-3688
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-9322
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-9090
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2014-8133
Ein Neustart des Rechners wird für die Übernahme der Änderungen der Aktualisierung erforderlich.
Security Update for Linux Kernel
Gehe zu
- LIGHTYS PC HILFE FORUM
- ↳ Welcome !
- WINDOWS BETRIEBSSYSTEME
- ↳ News und Informationen ( WINDOWS )
- ↳ DOS/3.x/9x/ME
- ↳ Windows NT/2000
- ↳ Windows XP
- ↳ Windows Vista
- ↳ Windows Server
- ↳ Windows 7
- ↳ Windows 8
- ↳ Windows 10
- ↳ Updates & Patches
- ↳ Tipps & Tricks - Windows
- ↳ Windows 9x
- ↳ Windows 2000/2003/XP
- ↳ Tipps: Windows Vista / Windows 7
- LINUX BETRIEBSSYSTEME
- ↳ News und Informationen ( LINUX )
- ↳ Linux ( Allgemein )
- ↳ Knoppix
- ↳ Suse
- ↳ Ubuntu
- ↳ Tipps & Tricks - Linux
- ↳ Knoppix Tipps
- ↳ Suse Tipps
- ↳ PCLinuxOS Tipps
- HARDWARE
- ↳ News und Informationen ( HARDWARE )
- ↳ Hardware Allgemein
- ↳ Router & Co
- ↳ Treiber ( Allgemein )
- ↳ ATI
- ↳ Creative
- ↳ NVidia
- ↳ PC Empfehlungen
- ↳ Einsteiger/ Office PC
- ↳ Allround PC
- ↳ Gamer/ Highend PC
- ↳ Notebooks
- SOFTWARE
- ↳ News und Informationen ( SOFTWARE )
- ↳ Bildbearbeitung
- ↳ Office
- ↳ LibreOffice / OpenOffice
- ↳ MS-Office
- ↳ Games
- ↳ Games - News
- ↳ Sonstige Software
- ↳ Tipps & Tricks
- ↳ Software-Empfehlungen
- INTERNET & NETZWERK
- ↳ News und Informationen ( INTERNET & NETZWERK )
- ↳ Antivirus, Malware und Firewalls
- ↳ Browser
- ↳ Firefox
- ↳ Firefox - Erweiterungen
- ↳ Internet Explorer
- ↳ Opera
- ↳ Vivaldi
- ↳ Mailprogramme
- ↳ Messenger
- ↳ AIM
- ↳ ICQ
- ↳ Miranda
- ↳ Pidgin ( GAIM )
- ↳ Skype
- ↳ Trillian
- ↳ Windows Live
- ↳ Internet & Netzwerk
- ↳ Surftipps
- ↳ Webdesign
- ↳ Webseitenvorstellung
- ↳ Sicherheit
- ↳ Forensysteme/-software
- ↳ phpbb
- ↳ phpmyforum
- ↳ Aktuelle Warn-/Sicherheitsmeldungen
- ↳ Linux
- ↳ Windows
- SMARTPHONES & CO
- ↳ Hardware
- ↳ Software
- SONSTIGES
- Download-Archiv
- ↳ Dateien / Tipps und Tricks
- ↳ Software - Archiv
