SystemExplorer 1.5 kann sowohl zum Installieren wie auch als Portable-Version heruntergeladen werden.SystemExplorer Homepage hat geschrieben:Major Features:Requirements:
- Detailed informations about Tasks, Processes, Modules, Startups, IE Addons, Uninstallers, Windows, Services, Drivers, Connections and Opened Files.
- Easy check of suspicious files via VirusTotal or Jotti service.
- Easy search details about file/process via online databases.
- Security Extension for automatic check of processes,modules and selected files.
- "New Task..." dialog with integrated AutoSearch and AutoCompletion.
- Action History for monitoring processes activities.
- Performance graphs for monitoring usage of system resources in time.
- System Snapshots for easy finding of system changes.
- System Report builds rich text report containing major informations about your System.
- Multilanguage and Plugins Support.
- Can be used as Task Manager replacement.
Licensing:
- OS: Windows XP or Windows Vista
- SystemExplorer is FREE for personal and commercial use!
Download: http://systemexplorer.mistergroup.org/
