Patchday bei SUSE
Die Sicherheitslücken betreffen die Linux-Systeme openSUSE 10.2/10.3/11.0, SUSE Linux Enterprise Server 9/10 und Novell Open Enterprise Server 1.x.
Quelle :
http://www.tecchannel.de/sicherheit/news/1775530/
... mmmmh !?
Mein Updater meldet bisher aber nüscht ! :???:
Non est mea culpa :oops:
... sagt ja auch keiner ! ;)
( aber ganz so dringend wird das Ganze dann wohl doch nicht sein !? )
jetzt ankömmt .... alles komplett als KernelUpdate ....
This patch updates the openSUSE 11.0 kernel to the 2.6.25.18 stable release. It also includes bugfixes and security fixes: CVE-2008-4410: The vmi_write_ldt_entry function in arch/x86/kernel/vmi_32.c in the Virtual Machine Interface (VMI) in the Linux kernel 2.6.26.5 invokes write_idt_entry where write_ldt_entry was intended, which allows local users to cause a denial of service (persistent application failure) via crafted function calls, related to the Java Runtime Environment (JRE) experiencing improper LDT selector state. sctp: Fix kernel panic while process protocol violation parameter. CVE-2008-3528: The ext[234] filesystem code fails to properly handle corrupted data structures. With a mounted filesystem image or partition that have corrupted dir->i_size and dir->i_blocks, a user performing either a read or write operation on the mounted image or partition can lead to a possible denial of service by spamming the logfile. CVE-2008-3526: Integer overflow in the sctp_setsockopt_auth_key function in net/sctp/socket.c in the Stream Control Transmission Protocol (sctp) implementation in the Linux kernel allows remote attackers to cause a denial of service (panic) or possibly have unspecified other impact via a crafted sca_keylength field associated with the SCTP_AUTH_KEY option. CVE-2008-3525: Added missing capability checks in sbni_ioctl(). CVE-2008-4576: SCTP in Linux kernel before 2.6.25.18 allows remote attackers to cause a denial of service (OOPS) via an INIT-ACK that states the peer does not support AUTH, which causes the sctp_process_init function to clean up active transports and triggers the OOPS when the T1-Init timer expires. CVE-2008-4445: The sctp_auth_ep_set_hmacs function in net/sctp/auth.c in the Stream Control Transmission Protocol (sctp) implementation in the Linux kernel before 2.6.26.4, when the SCTP-AUTH extension is enabled, does not verify that the identifier index is within the bounds established by SCTP_AUTH_HMAC_ID_MAX, which allows local users to obtain sensitive information via a crafted SCTP_HMAC_IDENT IOCTL request involving the sctp_getsockopt function. CVE-2008-3792: net/sctp/socket.c in the Stream Control Transmission Protocol (sctp) implementation in the Linux kernel 2.6.26.3 does not verify that the SCTP-AUTH extension is enabled before proceeding with SCTP-AUTH API functions, which allows attackers to cause a denial of service (panic) via vectors that result in calls to (1) sctp_setsockopt_auth_chunk, (2) sctp_setsockopt_hmac_ident, (3) sctp_setsockopt_auth_key, (4) sctp_setsockopt_active_key, (5) sctp_setsockopt_del_key, (6) sctp_getsockopt_maxburst, (7) sctp_getsockopt_active_key, (8) sctp_getsockopt_peer_auth_chunks, or (9) sctp_getsockopt_local_auth_chunks. CVE-2008-4113: The sctp_getsockopt_hmac_ident function in net/sctp/socket.c in the Stream Control Transmission Protocol (sctp) implementation in the Linux kernel before 2.6.26.4, when the SCTP-AUTH extension is enabled, relies on an untrusted length value to limit copying of data from kernel memory, which allows local users to obtain sensitive information via a crafted SCTP_HMAC_IDENT IOCTL request involving the sctp_getsockopt function. CVE-2008-3911: The proc_do_xprt function in net/sunrpc/sysctl.c in the Linux kernel 2.6.26.3 does not check the length of a certain buffer obtained from userspace, which allows local users to overflow a stack-based buffer and have unspecified other impact via a crafted read system call for the /proc/sys/sunrpc/transports file.
na das ist ja mal eine interessante Lektüre........... :lol:
Nicht wahr ... sehr interessant !? :D ( und schon inst. ) ;)
