Highlights
A couple of possible fixes for pages that never stop loading (NSL)
Stability fixes
Native skin fixes
Widgets should work when upgrading from 9.64
Icon fixes for Windows and Unix
Changelog
User Interface
Native skin fixes
Several fixes to strings that don't fit
Fixed Bug DSK-210876 (Reload Image is ignored after unfinished image load)
Fixed Bug DSK-262341 (Deleting Speed Dials aren't synced)
Fixed Bug DSK-262356 (Crash on exit after deleting private data)
Fixed Bug DSK-262389 (Crash in address bar dropdown)
Fixed Bug DSK-262523 ("Sychronize Opera" button in Speed Dial is not working)
Fixed Bug DSK-262622 (Crash when downloading spelling checker languages)
Core
Fixed high CPU on HTML5 spec page
Fixed Bug CORE-21052 (Using keys in match expressions causes crash)
Fixed Bug CORE-23155 (Blocking content that is added as an iframe src using JavaScript causes page to never stop loading)
Fixed Bug CORE-23169 (Opera claims collapsed selection isn't collapsed -- causes emoticon deletion in Gmail): Bad selection values in scripts when selection is the caret in documentedit
Fixed Bug DSK-248214 (Crash when saving a picture that has not been fully downloaded)
Fixed Bug DSK-258402 (Several images redirected to same URL can cause NSL)
Fixed Bug DSK-261860 (Upgrading Opera from 9.64 to 10, widgets connecting to the Internet get network problems on first run, works after reload)
Windows
Improved 8-bit icons, added 4-bit icons, PNG compressed bigger icons, lower quality icons for mail and chat
Fixed Bug DSK-262674 (Context menu height calculations off, causing "more items..." to show)
Unix
New/updated icons
Fixed Bug DSK-238564 (Icon files are not installed with install.sh)
Fixed Bug DSK-262492 (Old icon shows when dragging text)
Fixed Bug DSK-262757 (Qt3: Do not use XPM files to draw icon in system tray, use images from skin instead)
Fixed Bug DSK-252305 (Can not easily focus a widget on major Linux desktop environments)
http://my.opera.com/desktopteam/blog/20 ... andidate-2
Download Opera 10.0 Release Candidate 2
Windows MSI / Windows Classic
Mac (Universal) / Mac (Intel-only)
UNIX/Linux
... und um die Frage von Hooker noch mal aufzugreifen ...
... kann, da die RC1 und die RC2 kurz hintereinander veröffentlich wurden, nicht mehr lange dauern !?Hooker hat geschrieben:Orginalbeitrag Lesen
Ist eigentlich schon abzusehen, wann die O10 final erscheint?
