Paint.Net 3.5.3
Dieses Update des beliebten Freeware Bildbearbeiters behebt lediglich ein paar kleinere Bugs.
Der offizielle Changelog :
  • Fixed DirectDraw Surface (.dds) file format support for CPUs which do not have SSE2 (Pentium III, Athlon XP). Fixed an issue with the File->Save dialog related to file type plugins that were only written for opening (importing).
  • Fixed some crashes which were supposed to be "out of memory" errors.
  • Fixed a race condition with the New Image, Canvas Size, and Resize dialogs. If you typed extremely fast you could cause a crash by typing a negative number and immediately pressing OK or Enter.
  • Fixed a File->Save dialog issue in Win7/Vista where it could ask you about overwriting the wrong file.
Weitere Infos und Download gibt es auf dieser Site
Zurück zu „Updates & Patches“
