Linux kernel updat to 3.4.28
The Linux kernel was updated to 3.4.28 fixing various bugs
and security issues.
Following bugs were fixed:
- sysctl: Fixed vm.dirty_ratio sysctl name for desktop flavors
- bridge: Pull ip header into skb->data before looking into ip header (bnc#799209).
- x86: Hyper-V: register clocksource only if its advertised (bnc#792500).
- patches.fixes/thp-memcg-split-hugepage-for-memcg-oom-on-cow.patch:
thp, memcg: split hugepage for memcg oom on cow (bnc#793671).
- x86-64: fix hypercall page unwind info.
- frontends: handle backend CLOSED without CLOSING.
- xenbus: fix overflow check in xenbus_dev_write().
- x86: don't corrupt %eip when returning from a signal handler.
- Update Xen patches to 3.4.19.
- rpm/kernel-binary.spec.in: Do not remove fillup from the buildsystem (bnc#781327)
- rpm/config.sh: Set ARM project for IBS
- Refresh patches.xen/xen-x86-EFI (fix build after update to 3.4.17).
- ARM: Update config files: omap2plus: Set omapdrm as =y to allow for console=tty
- rpm/config.sh: Add openSUSE:12.2:ARM:Update OBS project
- ARM: Update config files: Disable HVC_DCC, refresh config files
- fix mmc on vexpress (kernel-default on armv7hl) for 3.4.
- rpm/kernel-binary.spec.in: Require coreutils in kernel-*-devel(bnc#783615)
- ARM: Update config files: Fix default config
- ARM: Update config files: Fix default config to work with vexpress
- Btrfs: fix enospc problems when deleting a subvol
- btrfs: enospc debugging messages
- ALSA: hda - Fix silent headphone output from Toshiba P200 (bnc#569991).
- ALSA: hda - Add inv-dmic model to possible Realtek codecs (bnc#569991).
- ALSA: hda - Add inverted mic quirks for Asus U41SV, Acer 1810TZ and AOD260 (bnc#569991).
- ALSA: hda - Add the inverted digital mic workaround to Realtek codecs (bnc#569991).
- rpm/kernel-binary.spec.in: Use a macro instead of /etc/IGNORE-KABI-BADNESS
- rpm/kernel-binary.spec.in: Also check for /etc/IGNORE-KABI-BADNESS file
This allows to control the kabi checker from outside of the package.
- memcg: oom: fix totalpages calculation for swappiness==0 (bnc#783965).
- ext4: completed_io locking cleanup.
- ext4: endless truncate due to nonlocked dio readers.
- ext4: ext4_inode_info diet.
- ext4: fix ext4_flush_completed_IO wait semantics.
- ext4: fix ext_remove_space for punch_hole case.
- ext4: fix unwritten counter leakage.
- ext4: give i_aiodio_unwritten a more appropriate name.
- ext4: punch_hole should wait for DIO writers.
- ext4: race-condition protection for
- ext4_convert_unwritten_extents_endio.
- ext4: serialize dio nonlocked reads with defrag workers.
- ext4: serialize fallocate with ext4_convert_unwritten_extents.
- ext4: serialize unlocked dio reads with truncate.
- x86/kbuild: archscripts depends on scripts_basic.
- kbuild: Fix gcc -x syntax (bnc#773831).
- Disable hyper-v patch to avoid kABI changes:
Drivers: hv: Explicitly size elements of protocol structures
- Hyper-V KVP IP injection (fate#31441)
- drivers: net: Remove casts to same type.
- drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op.
- hyperv: Move wait completion msg code into rndis_filter_halt_device().
- hyperv: Add comments for the extended buffer after RNDIS message.
- Drivers: hv: Cleanup the guest ID computation.
- Drivers: hv: vmbus: Use the standard format string to format GUIDs.
- Drivers: hv: Add KVP definitions for IP address injection.
- Drivers: hv: kvp: Cleanup error handling in KVP.
- Drivers: hv: Explicitly size elements of protocol structures.
- Drivers: hv: kvp: Support the new IP injection messages.
- Tools: hv: Prepare to expand kvp_get_ip_address() functionality.
- Tools: hv: Further refactor kvp_get_ip_address().
- Tools: hv: Gather address family information.
- Tools: hv: Gather subnet information.
- Tools: hv: Represent the ipv6 mask using CIDR notation.
- Tools: hv: Gather ipv[4,6] gateway information.
- hv: fail the probing immediately when we are not in hyperv platform.
- hv: vmbus_drv: detect hyperv through x86_hyper.
- Tools: hv: Get rid of some unused variables.
- Tools: hv: Correctly type string variables.
- Tools: hv: Add an example script to retrieve DNS entries.
- Tools: hv: Gather DNS information.
- Drivers: hv: kvp: Copy the address family information.
- Tools: hv: Add an example script to retrieve dhcp state.
- Tools: hv: Gather DHCP information.
- Tools: hv: Add an example script to configure an interface.
- Tools: hv: Implement the KVP verb - KVP_OP_SET_IP_INFO.
- Tools: hv: Rename the function kvp_get_ip_address().
- Tools: hv: Implement the KVP verb - KVP_OP_GET_IP_INFO.
- tools/hv: Fix file handle leak.
- tools/hv: Fix exit() error code.
- tools/hv: Check for read/write errors.
- tools/hv: Parse /etc/os-release.
- hyperv: Fix the max_xfer_size in RNDIS initialization.
- hyperv: Fix the missing return value in rndis_filter_set_packet_filter().
- hyperv: Fix page buffer handling in rndis_filter_send_request().
- hyperv: Remove extra allocated space for recv_pkt_list elements.
- hyperv: Report actual status in receive completion packet.
- hyperv: Add buffer for extended info after the RNDIS response message.
- rpm/kernel-binary.spec.in: enable Conflicts for apparmor, udev and lvm2 also for vanilla kernel
- rpm/kernel-binary.spec.in: add Conflicht: hyper-v to make sure the daemon is in sync with the kernel (bnc#770763 , fate#314441)
https://bugzilla.novell.com/show_bug.cgi?id=569991
https://bugzilla.novell.com/show_bug.cgi?id=770763
https://bugzilla.novell.com/show_bug.cgi?id=771392
https://bugzilla.novell.com/show_bug.cgi?id=773831
https://bugzilla.novell.com/show_bug.cgi?id=774859
https://bugzilla.novell.com/show_bug.cgi?id=776925
https://bugzilla.novell.com/show_bug.cgi?id=778630
https://bugzilla.novell.com/show_bug.cgi?id=780624
https://bugzilla.novell.com/show_bug.cgi?id=781327
https://bugzilla.novell.com/show_bug.cgi?id=783615
https://bugzilla.novell.com/show_bug.cgi?id=783965
https://bugzilla.novell.com/show_bug.cgi?id=784192
https://bugzilla.novell.com/show_bug.cgi?id=792500
https://bugzilla.novell.com/show_bug.cgi?id=793671
https://bugzilla.novell.com/show_bug.cgi?id=799209
http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-3520
Veraltete Pakete:
/• kernel-desktop - 3.4.6-2.10.1
/• kernel-desktop - 3.4.11-2.16.1
