linux kernel security and bugfix update
The openSUSE 12.3 kernel was updated to fix a critical security issue
and two reiserfs bugs.
CVE-2013-2850: Incorrect strncpy usage in the network
listening part of the iscsi target driver could have been
used by remote attackers to crash the kernel or execute
code.
This required the iscsi target running on the machine
and the attacker able to make a network connection to it
(aka not filtered by firewalls).
Bugs fixed:
- reiserfs: fix spurious multiple-fill in reiserfs_readdir_dentry
(bnc#822722).
- reiserfs: fix problems with chowning setuid file w/ xattrs
(bnc#790920).
- iscsi-target: fix heap buffer overflow on error (CVE-2013-2850,
bnc#821560).
• https://bugzilla.novell.com/show_bug.cgi?id=790920
• https://bugzilla.novell.com/show_bug.cgi?id=821560
• https://bugzilla.novell.com/show_bug.cgi?id=822722
Weitere Informationen zu dieser Sicherheitsaktualisierung sind auf dieser Webseite verfügbar:
• http://cve.mitre.org/cgi-bin/cvename.cg ... -2013-2850
Ein Neustart des Rechners wird für die Übernahme der Änderungen der Aktualisierung erforderlich.
